Forum JST XH 2.54 right angle library
  • Answers 2 answers
  • Views 8321 views
  • jst-xh
  • connector
  • xh
  • jst
  • 2.54
beic
beic over 5 years ago
Hi there,
Anyone knows where can I find Eagle library v7.6 for JST XH 2.54 right angled connectors (2P, 3P, 4P and 5P)?
Thank you!
  • beic
    0 beic over 5 years ago in reply to mirth
    Thank you!
    I found out that posted library doesn't have right angle type connectors inside.
    But, on the same website I found this one, and it has a few variant of right angle connectors.
    https://www.diymodules.org/download/eagle-libs/shr/0000000053/con-JST%20XH.lbr
    Printed out both of 4 pin layout and it seems that the 2.50mm and 2.54mm are the same, just named differently.
  • mirth
    0 mirth over 5 years ago
    Try
    https://www.diymodules.org/eagle-show-library?type=usr&id=1012211612&part=Rembrandt+Electronics+-+JST+XH+Connectors+v1-0…
    Im using Eagle V7.7.0
    Clicked the Original File Download Option
    P.S. Always print Part on paper to test before manufacture
    0 shabaz over 5 years ago
    Hi Viktor,
    Just to be clear, if you attempt to make these yourself, the pitch is 2.50mm, not 2.54mm as mentioned above and in the tag.
