Forum How to upside down pin of a Op amp in schematic editor?
  • Views 1251 views
huayuliang
huayuliang over 16 years ago
I do not know if EAGLE has this feature.
but this feature is very usefull, only swap two pin of a op amp will make schematic's drawing become to more easy..
    0 e14 Contributor over 16 years ago in reply to huayuliang
    I don't do a lot of work with op-amps, but I do do a bit with USB - and often the USB connector is upsidedown for my circuit - so I flip it horizontally, and then rotate it through 180 degrees to get the pins "the right way around".
    You shouldn't need to design it from right-to-left; it's just the initial placement where you flip&rotate it.
  • huayuliang
    0 huayuliang over 16 years ago in reply to e14 Contributor
    yeah, this a usefull method.power rail all invoked from ic. but I used to draw from left to right.
    You can flip it horizontally, and then rotate it through 180 degrees - but I am assuming that it's just a basic op-amp whose power rails are in another gate (otherwise they'd be swapped too).
