Forum Track Corner and End Move and Delete
  • Subscribers 187 subscribers
  • Views 397 views
Hi, I have a couple of questions,
  • is there a simple way to delete track corners?
  • can track corners and ends be moved to another pad in the same net?
Any help would be appreciated.
  • Richard_H
    0 Richard_H over 16 years ago
    John,
    you can use the MITER command to round corners. I hope this is what you asked for....
    Concerning your 2nd question: As soon as a track is connected to a pad you can't simply move it to another pad. You have to draw a new track at the other pad with the ROUTE command.
    In case you draw the layout without a schematic in the background, you could use GROUPT/CUT/PASTE for duplicating wires/tracks. But in the case the wire/signal name will change.
    Richard
