Forum Problem Accessing DesignLink from Eagle 5.10.0 - "unexpected end of file"
  • Replies 17 replies
  • Views 2088 views
  • designlink
  • cadsoft
I recently upgraded to Eagle 5.10.0 for Linux.
I also registed for Design Link
I am able to start design link and I get the dialog box.
However, if I try to do a search, after a delay I get an error message: "XML-error unexpected end of file.
I am able to log into my Design link account with a web browser, so it appears my user name and pass word are okay.
    0 e14 Contributor over 16 years ago in reply to Richard_H
    Hello!
    I solved the problem by accessing the internet via Microsoft's ISA Server.
    It seems that our proxy has problems with SOAP or something like that.
    But anyway, thank you for your help.
    Greetings, Norbert
  • Richard_H
    0 Richard_H over 16 years ago in reply to e14 Contributor
    Hi again,
    do you use a proxy for internet access?
    If yes, did you configure it in EAGLE? Please check the settings in the EAGLE Contorl Panel, Help menu, Check for update, Configure.
    Richard
    PS: Maybe it is a matter of the settings of your firewall?
    Hi Richard,
    my online e-mail (inode.at) uses the https protocol and i can read my mails.
    Greetings, Norbert
  • Richard_H
    Hi Norbert,
    this looks as if the proxy does not allow the https protocol. Could you or your sys admin check this?
    HTH
    Richard
    0 e14 Contributor over 16 years ago in reply to e14 Contributor
    Hello Everybody!
    I am experiencing exactly the same problem. I have installed Eagle 5.10.0 on a Windows 7 x64 machine.
    The internet is accessed via a proxy which is properly configured in Eagle.
    When i do a search in the Farnell DesignLink Interface two windows pop up in sequence.
    The first shows a progress bar staying at 0% the second following message
    "../EAGLE-5.10.0/ulp/designlink.ulp(264):
    XML-Error (1, 1): unexpected end of file"
    By the way, the first window disappears very quickly.
    After exiting the second window, the Farnell DesignLink Interface shows this message:
    "Error while accessing 'https://uk.farnell.com/pffind/services/SearchService':
    1 Connection refused"
    When i access the URL stated above in a web browser i get this:
    "<faultstring>
    The endpoint reference (EPR) for the Operation not found is /pffind/services/SearchService and the WSA Action = null
    </faultstring>"
    I hope anyone has an idea to it.
    Greetings, Norbert
    Hi Richard:
    I will investigate my internet connection.
    It definitely appears that there is some kind of "time out" issue as the connection seems to take a long time.
    Thank you
    Dale
  • Richard_H
    Hi Dale,
    I hoped for a positive answer...... image
    But you are right, changing the LANG variable to en_GB contacts the Premier Farnell server in the UK. I hoped that this connection would work.
    The message "unexpected end of file" indicates that there is traffic from your computer to the Farnell/Newark server and back and suddenly the connection fails or gets too slow. Looks as if there is problem with your internet connection.
    Did you experience problems in the past, not only with Newark also with other servers? If you download, for example, the EAGLE software package from cadsoft.de or cadsoftusa.com, how long does this take? Do you share the internet access with anybody else? Could there be sometimes too much traffic?
    Richard
    Hi Richard:
    I tried the new ulp, without success.
    I also ran Eagle with the LANG=en_GB setting, and tried both ULPs , but still got the same result for both.
    I also noticed that with the new LANG variable it did try to use the Premier Farnell server.
    Thank you
    Dale
  • Richard_H
    Hi Dale,
    just sent the modified ULP to your private email address.
    If you don't mind you could make a further test. Please start EAGLE with an executable script where we first change the LANG variable. It could look like this:
      LANG=en_GB
      /now/follows/the_path/to/start/eagle
    With this LANG setting the designlink.ulp will won't contact the Newark server, but the Premier Farnell server in the UK. Does this work?
    BTW:  You could also type the commands in a Terminal window, so you don't have to write a script.
    Richard
    Hi Richard
    The OS version is Linux 2.6.26.8-57.fc8; the distribution is Fedora Core 8
    I am located in Western Canada.
    There may be a time out issue; when I do a search from within DesignLink there is a time delay while it is searching before the error message appears.
    Also, for some reason, the Newark website seems to take a long time to respond on my system (longer than most other websites)
    I am not sure of my connection speed, but I do have an ADSL connection.
    Thank you
    Dale
