Forum Importing Specctra SES files into Eagle Cad
  • Replies 12 replies
  • Subscribers 190 subscribers
  • Views 3329 views
  • ulp
  • topor
Short Story:
I'm trying import specctra SES formated files into eaglecad, I'm told there is a ulp for that. But I'm having no luck finding it.
Long Story:
I'm trying to use TopoRs router with eaglecad. So I can export eaglecad .brd files to TopoR by first converting it to dsn files using a ulp i found here. http://www.freerouting.net/download/brd_to_dsn.ulp
After TopoR is done routing it can only export files in SES , DXF formats. Do u guys know of any ulps or ways to import these files into eagecad.
    0 e14 Contributor over 15 years ago in reply to Jorge_Garcia
    Thnx for the reply Jorge
    Ok so dxf2scr is not working for me. I tried running the SCR it generates in a empty brd files.. and nothing happens. I looked at the dxf file that topor generates with a third part dxf viewer and it looks fine.  The description for dxf2scr says it only does "board outlines from AutoCAD to Eagle" so it may not import the routing anyway.
    I tried dxf2scr-1 , its look like its just a clone with a gui , and it doesn't work too.
    the DXF importer from EagleCad power tools, seems to be the only one that kinda works. It presemnts me a list of layers in the dxf and how they should be transfered to eaglecad like top to layer 1 , bottom to layer 16. But when i run it it only seems to translate the pads and not the traces and routing. Could be because I'm running it in demo mode.
  • Jorge_Garcia
    0 Jorge_Garcia over 16 years ago
    Hi Kvik,
    You can import dxf files into EAGLE using dxf2scr. You can find it on the website www.cadsoftusa.com-> Downloads->Miscellaneous.
    hth,
    Jorge Garcia
