Forum Single Layer PCB
  • Views 978 views
Single Layer PCB
PhG
PhG over 15 years ago
I'm new to Element14 and Eagle as well, so maybe my
question is somewhat too simple for you guys.
I noticed that Eagle always creates a 2 layer PCB.
However, I only require small single layer PCB's.
How do I set it up or how do I force Eagle to design
only single layers ?
Thanks and btw, congratz with this awesome site !
Best regards,
Philip
  • PhG
    0 PhG over 15 years ago in reply to Richard_H
    Hi Richard,
    Great ! It worked. I'll get my hands on it and let you know my progress image
    Greetz,
    Philip
    Date: Mon, 23 May 2011 06:41:13 +0000
    To: philip_gevaert@hotmail.com
    Subject: - Re: Single Layer PCB
        created by Richard_H in CadSoft EAGLE - View the full discussion
    Hi Phil, you have to load all libraries into the memory first brfore EAGLE can use them in the ADD dialogue. Please go to the EAGLE Control Panel. There you have the Tree view that shows the libraries branch. Right mouse click onto it and select "Load all libraries" from the context menu. Best regards,Richard
        Reply to this message by going to element14
         Start a new discussion in CadSoft EAGLE at element14
    Sitemap | Feedback & Support | Contact Us | Terms of Use | FAQ | About element14
    **************************Disclaimer**************************
    The contents of this e-mail and any file transmitted with it are confidential and intended solely for the individual or entity to whom they are addressed.
    The content may also contain legal, professional or other privileged information.
    If you received this e-mail in error, please destroy it immediately.
    You should not copy or use it for any purpose nor disclose its contents to any other person.
    The views stated herein do not necessarily represent the view of the Company.
    Please ensure you have adequate virus protection before you open or detach any documents from this transmission.
    The Company does not accept any liability for  viruses.
    Premier Farnell plc
    150 Armley Road
    Leeds
    LS12 2QQ
    Telephone +44 (0) 870 129 8608
    Fax +44 (0) 870 129 8610
    Registered in England
    Company Number 876412
    Registered Office: Farnell House, Forge Lane, Leeds LS12 2NE
  • Richard_H
    0 Richard_H over 15 years ago in reply to PhG
    Hi Phil,
    Best regards,
    Richard
  • PhG
    Hi Richard,
    I've made the change. However, when I start a new project (either schematic or board)
    I no longer have libraries. How do I reload those ?
    Best regards,
    Philip
    Date: Fri, 20 May 2011 09:32:28 +0000
    Hi Philip, you are right the default setting in EAGLE is to create two layer boards. This is defined in the Design Rules, Layers tab. There is written in the Setup line  (1*16)   which allows to use two layers (1 and 16) and set Vias (the parenthesis around the term). If you want to define/use only one layer (without vias) then write into the Setup line: 16 Or simply leave it as it is and use only wires in layer 16, Bottom. Regards,Richard
    Premier Farnell plc
    150 Armley Road
    Leeds
    LS12 2QQ
  • PhG
    Hi Richard,
    Thanks !! I appreciate the quick and clear response !
    This was very usefull.
    Best regards,
    Philip
    Premier Farnell plc
    150 Armley Road
    Leeds
    LS12 2QQ
  • Richard_H
    Hi Philip,
    Richard
