Forum Missing air wire when I switch from schematic to board
  • Subscribers 186 subscribers
  • Views 409 views
After I’m done with my schematic I ran erc check result in  overlap, unconnected pins and so on All my parts on grid I try to rewire with wire/nets/bus nothing work every time I’m missing all air wire Try to clear all error and switch to board I can’t rout my part .I’m using  v 5.11 downloaded from your forum and pc vista  any one can tell me what I’m doing wrong please I been working on it for three days Thank you
  • Oliver
    0 Oliver over 15 years ago
    I can not give you the true issues if there is no original schematic file. i guess that some aire wire are missing when you switch schematic to board, not all air wires missing. For example, there are more than three nodes shuld be connected on one net abstractly, in fact one node is not truly connected. ERC can not check out the error in this situation.
    give me the schematic file and i will tell you why
