Forum Re: Can Eagle V6 create "jumpers wires" in single layer board?
  • Views 1113 views
I often design PCB with single bottom layer. I would like to know if Eagle V6 can create "jumper connection" where it is necessary.
In my country, Mauritius, there is no PCB manufacturer. Hence I have to make my own PCB using Photo sensitive board and etching solution.
I also note that there is no auto placement of the components. Therefore, I have to do trial and error placement to cope with.
Please help me to find solution and advise me the best way to use Eagle V6.
Thanking you before hand.
  • mrosenau
    0 mrosenau over 14 years ago
    It's not automatic, but you can fake jumpers by designing a 2 layer board. Place all the routing on the bottom layer (the layer you plan to etch) and route your jumpers as traces on the top layer. These top layer traces will not exist on your physical board, but the holes will be shown shown as vias and the jumpers will be shown as top layer traces.  After your board is etched, you insert the missing top layer as jumpers.
    Keep the top layer traces simple, straight and don't go under any components and this technique works.
    This is also eplained in a different way here: http://www.element14.com/community/message/39405#39405/l/automatic-insert-of-jumpers
    Good-luck and welcome to low-budget boards!
    Mark R
  • Richard_H
    0 Richard_H over 14 years ago
    if you are making singlesided boards and you would like to use some wire jumpers, you could simply place use two vias for it. When you are ROUTEing you can set vias directly with Shift key + left mouse click.
    EAGLE does not offer autoplacement function, so you have to arrange the components manually. There are two projects that are realized through ULPs which offer an autoplace function. Please look at
    http://www.cadsoft.de/cadsoft-downloads/  and search for "autoplace". Maybe these ULPs work for you.
    Richard
