Is there any way to check in the board if all the yellow wires have been connected? Sometimes you forget a short yellow wire, so the board is wrong.
Xabi.
Xabi.
Hi Jim,
set the parameter Catch factor in the Options/Set/Misc to 0.
Now simply use the ROUTE command and click into the drawing. The next airwire will automatically jump to the mouse cursor and you have found it.
Richard
Whilst the answers already here are technically correct; I sometimes find that there is a tiny little airwire left unattached that can be hard to spot on a densely populated board.
What I do for these is to hide the top and bottom layers, then make the airwire colour something bright like a red or pink, it usually stands out quite well.
It would be nice to have a "make the airwires obvious" button sometimes!
-Jim
