Forum Printing yellow
  • Subscribers 187 subscribers
  • Views 331 views
Printing yellow
Hi all,
When I try to print yellow objects (tracks, pads etc..) the objects appear gray in the print preview and also print gray. Other colours seem to be fine just not yellow. Is this a bug/feature? How do I print in yellow?
Also, how the **** do I search the forum? I can't find a search button anywhere apart from the one at the top of the screen which searches everything and doesn't seem to return forum posts?
Cheers
Rob
  • Richard_H
    0 Richard_H over 14 years ago
    what is the background color you are using? Is it white?
    For prining EAGLE always takes the white palette. So in case you defined the colors for the black palette, you should do so for the white palette as well.
    Richard
    BTW: If you don't like the web based front-end here on element14, you could use the CadSoft newsgroups directly: news://news.cadsoft.de
