Forum How do I re-add a component after it has been "dropped"
  • Views 344 views
I'm new to EAGLE and made what is surely a novice mistake.  I was using the "Add a part" tool and searched and found the component I wanted to place on the schematic.  I clicked the "Drop" button thinking this would drop it item into my schematic, but instead those components are now gone from my list of components.
Is there any way to get these back?
  • robotonics
    0 robotonics over 14 years ago
    Hi
    Dont worry...
    All you need to do is whilst in the schematic editor, select the Libray menu and then select USE, a window will open allowing you to select the location of the Library you just dropped.
    Select the Library and then go back to the schematic, select ADD to add a part, and you will find the Library restored.
