Hello Respected SIR,
I have already mailed you regarding the error I am encountring in the Eagle software,please If you can help me with it
THANK YOU
THANK YOU
Thank you for your reply I thought you are not going to reply me so I was just working with that and I was able to reduce them from 144 to 36 errors but now the only errors I am encountring are of the MRF24WBOMA device pads.The solution of the error you mentioned If you can explain little bit as I am new to PCB designing please If you dont mind.Thankin you in advance.
as far as I can see the silk screen of connector 1 and 2 runs over the soldering area of the pads. This can make trouble, because it could happen that the solder connection is not properly made. If you want to avoid such errors you have to change the silk screen in the library so that it does not cover pads.
HTH
Best regards,
Richard
