Forum change value group of components
  • Views 826 views
Hi Richard
Can you help me please
I need to change of value to several components, especifically resistors. I found an ULP "cmd-change-value-group" but I do not know how use it.
There is other way for do it?
thanks
Jaime Bedoya
  • Richard_H
    0 Richard_H over 13 years ago in reply to e14 Contributor
    Hi Jaime,
    the ULP runs in the board, but EAGLE's Back and Forward Annotation transfers the new values into schematic automatically.
    Richard
    0 e14 Contributor over 13 years ago in reply to Richard_H
    Hi Richard
    thanks for your answer
    But I have an other question about it. This command only function in the PCB?
    how can I to change values the groups in the schematic?
    thanks
    Jaime Bedoya
  • Richard_H
    the ULP is okay for changing the values of a group of components. You have to use the GROUP command and select all components that should be changed. Then start the ULP via the command line directly. Let's say the new value should be 100k. Type in the command line:
    run cmd-change-value-group.ulp 100k
    Richard
