Forum create a trace without solder mask for manual tinning
  • Views 489 views
  • mask
  • eagle
  • trace
  • solder
  • cadsoft
SouthernAtHeart
SouthernAtHeart over 13 years ago
How do I put a few traces on my board that won't be covered over with solder mask, so I can manually build them up a little with solder (to carry extra current)
thanks.
  • SouthernAtHeart
    0 SouthernAtHeart over 13 years ago
    ...I think I found a way, but I better be sure before sending off for a board.
    Can I draw a polygon on the tStop layer, and that will be 'solderable' on the finished board?  A polygon will be good because I can draw just where I want to add some extra solder.
    thanks
    edit...
    Or is it the tCream layer???  Hopefully someone has the best/correct solution to do this.
    Please advise, thanks again.
