Forum Hatch GND at an angle?
  • Subscribers 189 subscribers
  • Views 1307 views
Hi, Richard/ Experts out there!
I am  new to eagle, Can I create a hatch GND , with the lines of the hatch at a 45 degree angle with respect to base of PCB in Eagle. I couldn't find this option.
Right now when I try doing this the Lines of the web are "---" and "|"  , where as I wanted them as" / "and " \ " attaching a pic the way i wanted.. I hope the question is clear!
Thank you!
Jay
  • Richard_H
    0 Richard_H over 13 years ago in reply to jameslittlefield
    Hi James,
    indeed this would be an option... image  Thanks for the workaround.
    Richard
  • jameslittlefield
    0 jameslittlefield over 13 years ago
    There is a way that you can get what you want (at least in 5.x) but its not real convenient.    I had to do this for a flex project.   Heres the steps as I remember them.
    1. Do your board layout including the hatched planes
    2. When everything is done,  rip-up the hatched planes
    3. Activate all layers,  group everything, and rotate the entire board 45 degrees
    4. Click on ratsnest to re-hatch the planes (they are still hatched parallel to the X-Y axes but now the board is rotated 45).
    5. Run your cam job to generate gerbers.
    6. Run your favorite gerb viewer/editor on the generated gerbers to rotate everything back to 0 deg.
    Cheers,
    Jim
    0 e14 Contributor over 13 years ago in reply to Richard_H
    Thats sad! image .
    Anyway thank you for your quick answer!.
    Regards
    Jay
  • Richard_H
    Hi Jay,
    I'm sorry, but this is not possible. There is no option to have rotate the filling of hatched polygons.
    Richard
