Forum unconnected pin in library part
  • Views 1566 views
japper
japper over 13 years ago
I took a part from a library and modified it from a through hole device to a SMD device and now
I get the following error message when I try to load the library part (and it does not
allow me to place the part):
Device CD74hc4067SM96 has unconnected pin (A/VCC)
Is there a way for me to open this device and fix this problem so that I can place the part?
I downloaded this library again, closed EagleCad, deleted the exisitng library, and copied the downloaded
copy of the library in its place but it gives me the same error...
thanks for any help on this...
  • japper
    0 japper over 13 years ago in reply to Richard_H
    Thank you Richard
  • Richard_H
    0 Richard_H over 13 years ago
    HI,
    please check the Device in the library. There you can do the CONNECT where your have to connect every pin with one or more pads.
    Richard
