Forum .CMP File not generated from CAM file
  • Subscribers 187 subscribers
  • Views 1284 views
japper
japper over 12 years ago
I am using Eagle Cad light v 6.4.0 and have a CAM file that is set up to create a CMP file for
the component side but this .cmp file is not being created.
Below is the entry in my Cam file set up for the Component side. What am I doing wrong?
  • Richard_H
    0 Richard_H over 12 years ago in reply to japper
    .cmp is the usual file extension for the bottom side Gerber file for more than 20 years now.
    Is it really a problem of not creating the file or could it be a matter of the Windows Explorer not showing files with already assigned file extensions? As far as I know Explorer does not show known file extensions by default. Could you please check this?
    On the other hand it is no problem to use a different file extension. You could for example use *.top instead of *.cmp  and *.bot instead of *.sol.
    Best regards,
    Richard
  • japper
    0 japper over 12 years ago
    It looks like the CMP file has been hijacked and associated with a Zuken viewer...
    All the other gerber files are associated with a windows shell program.
    Does anyone know what the correct choice for file association should be for this file?
