Forum How to save Eagle Cad settings
  • Subscribers 189 subscribers
  • Views 1315 views
SouthernAtHeart
SouthernAtHeart over 12 years ago
I can't find any documentation on how to edit some of the preferences.  Like for example, to have the grid in mm instead of inches, or have the grid a different size.  When I change it, it always changes back when I restart.   Can someone please point me in the right direction.  Thanks.
  • SouthernAtHeart
    0 SouthernAtHeart over 10 years ago
    Is there a settings or ratio or something that eagle cad uses to calculate the diameter of vias when the diameter is set to auto?  I'd like to leave it on auto, but I'd like it to be slightly larger than it typically is...  If there is a setting for this, can I add it to my startup .scr file?  Thanks.
  • Richard_H
    0 Richard_H over 12 years ago
    basic settings are made in eagle.scr. Please take a look into the manual. Chapter 5 deals with configuration and there can be found information about the eagle script file.
    Richard Hammerl
    the same query I have also i
