Forum Multiple sub-design in one design (easily in Eagle 5, hardly in Eagle 6)
  • Views 682 views
  • copy
  • eagle
Working with Eagle 5 I had several times copied a sub-design. The procedure worked like this:
     open only Schematic:
          Name components and Nets, so that they don't end with number (like R1A)
          Cut sub-design
          Paste sub-design (the copied parts have now R1A1, R1A2, .... names, only GND stays with the same name)
     open only Layout (do the same):
          Cut
          Paste (the copied parts have now R1A1, R1A2, .... also GND gets renamed to GND1, GND2 ...)
               but that's easily correctable.
     Schematic and Layout are almost always consistent
Now working with Eagle 6 the procedure doesn't work anymore (no CUT button, so I use Copy):
          Copy sub-design
          Paste sub-design (the copied parts have now R1A1, R1A2, Nets are not renamed and have identical name !!!)
          Copy
     Therefore now the Schematic and Layout are total mess.
I was looking for UPLs to performe this taks, but without any success. So if there a better way (other than downgrading back to Eagle 5) I will be happy to use it.
Pavel
    0 e14 Contributor over 12 years ago in reply to Richard_H
    Hello Richard,
    Thank you for very helpful answer.
    I'm using Eagle 6.4.0. the Nets are labeled, and I had just tested, that unlabeled nets indeed get renamed.
    I didn't know about this new Eagle drawing Import feature. Thank you for that info, I will probably use it.
    Pavel
  • Richard_H
    0 Richard_H over 12 years ago
    EAGLE 5 and 6 should behave exactly the same. Which EAGLE version 6 do you use? Are there maybe labels set at the nets. In this case nets won't be renamed.
    By the way: Do you know that you can import consiten board/schematic file pairs into your design? This makes things much easier (menu File/Import.../ EAGLE drawing)
    regards,
    Richard
