Forum Ω vs R and μF vs uF
  • Replies 11 replies
  • Answers 2 answers
  • Subscribers 193 subscribers
  • Views 1921 views
  • symbols
Ω vs R and μF vs uF
Workshopshed
When designing board what is the recommendation for putting in the values for resistors and capacitors?
Should I use the Greek letters or use the Latin equivalents.
Does this make any difference when using "Design Link" ?
  • Problemchild
    0 Problemchild over 11 years ago in reply to Workshopshed
    I mix them and don't find a problem image
  • Problemchild
    Greek Characters are correct.
    Roman characters "u", "R" are used because they are more simply found and better supported on modern computers with out support of extra fonts etc.
    It's unusual to see the Greek characters in diagrams these days because of this.
    Using hand drawn diagrams this didn't used to be the case.
  • Workshopshed
    0 Workshopshed over 11 years ago in reply to mcb1
    Unfortunately we cling to our antiquated systems here in the US
    In the UK we do tend to mix things here which I find very annoying, I'll stick with the SI units that makes the most sense. Cadsoft seems to have a strong German team so I should be good with that and my experiments are consistent with what others suggested in that the characters are mostly ignored.
    0 mcb1 over 11 years ago in reply to jw0752
    Yes I noticed except I do like cubic inches, and the more the faster it goes.....image
    That may be why I've been seeing it more .... thanks
    0 jw0752 over 11 years ago in reply to mcb1
    What you describe is actually an international standard of the SI system. I wouldn't be so smart except that Shabaz gave me a link today to something else and they had a paragraph about the SI system. It makes really good sense and I will convert to it in my notation henceforth. Unfortunately we cling to our antiquated systems here in the US so it may be a while before our schools follow suit.
    0 mcb1 over 11 years ago in reply to johnbeetem
    I've tended to see R for the resistors this means you don't require the appropriate font.
    ie 100R for 100 ohms, 1k5 for 1500 Ohms or 1R5 for a 1.5 ohm
    This tends to work since the little tiny dot often disappears or is hard to read ...etc
  • johnbeetem
    0 johnbeetem over 11 years ago in reply to jw0752
    The convention I use (and have seen used a lot) is not to show any unit for resistors, since they are usually the most common part.  So "100" means a 100Ω resistor and "1K" means 1KΩ.  Everybody else gets a unit, like 0.1uF capacitor or 8mH inductor.  I always use "uF" for μF in schematics -- this has been a common substitute for decades (at least).  Relying on the Symbol font to be present can be risky -- I've seen data sheets that recommend 1KW resistors image when they meant 1KΩ.
    Hi Andy, Like many things today the rules are more flexible. From a purely scientific approach the Greek letters are more correct but the unavailablity of the Greek letters on many applications and computers make the more common replacements acceptable. I always use the uF when working on the computer and the Greek when hand writing. As long as you label for best communication and understanding you will probably not encounter any problems.
  • ingit
    0 ingit over 11 years ago in reply to Workshopshed
    Value works better than just name , I always use values to search not the package yeah sometimes i use both to make search more precise for example " 100nF 0402" or " 0.1uf 0402" this gives less than 50 search results which are easy to look at but while using " 0402 capacitor" gives a endless list of capacitors of all values.
  • Workshopshed
    0 Workshopshed over 11 years ago in reply to ingit
    yes, but that does not work for resistors and capacitors as you don't specify the value in the part selection just the device size and type e.g. a 0402 SMD Resistor, the value is provided separately.
