Forum Ω vs R and μF vs uF
  • Replies 11 replies
  • Answers 2 answers
  • Subscribers 181 subscribers
  • Views 1284 views
  • symbols
Ω vs R and μF vs uF
Workshopshed
When designing board what is the recommendation for putting in the values for resistors and capacitors?
Should I use the Greek letters or use the Latin equivalents.
Does this make any difference when using "Design Link" ?
    jw0752 over 11 years ago +3 verified
    Hi Andy, Like many things today the rules are more flexible. From a purely scientific approach the Greek letters are more correct but the unavailablity of the Greek letters on many applications and computers…
  • johnbeetem
    johnbeetem over 11 years ago in reply to jw0752 +1 suggested
    The convention I use (and have seen used a lot) is not to show any unit for resistors, since they are usually the most common part. So "100" means a 100Ω resistor and "1K" means 1KΩ. Everybody else gets…
    mcb1 over 11 years ago in reply to johnbeetem +1 suggested
    I've tended to see R for the resistors this means you don't require the appropriate font. ie 100R for 100 ohms, 1k5 for 1500 Ohms or 1R5 for a 1.5 ohm This tends to work since the little tiny dot often…
  • Problemchild
    0 Problemchild over 11 years ago in reply to Workshopshed
    I mix them and don't find a problem image
