Forum about Meander
  • Subscribers 187 subscribers
  • Views 523 views
about Meander
권슬아
권슬아 over 13 years ago
Hello, Richard!
I have a question about 'Meander' of Command button in EAGLE!
when I use the 'Meander,' it works always differently
(now works, now don't works, and operation poins are always different! )
so I can't find the rule of Meander.
How can I use the Meander more easily??
Thanks & Regards !
  • Richard_H
    Richard_H over 13 years ago
    it is quite easy. If MEANDER command is active, click on the wire that should be treated. Now move the mouse away from the wire. The distance of the mouse decides about its appearance. The height of the meander is influenced by the distance perpendicular to the wire, the number of meanders depends on the distance in parallel direction to the wire. The right mouse button decides whether the meander is symmetric or asymmetric.
    Richard
