Forum Devices with repeated pins
  • Subscribers 187 subscribers
  • Views 221 views
jfowkes
jfowkes over 15 years ago
This question is specific to one device, but is applicable to many.
In the battery library, there is a device CR2032H (a horizontal CR2032 battery).
If the device is opened in the library editor, all three pins appear to be defined (see attached image) - that is, two +ve and one -ve.
However, when used in a project, the second +ve pin remains unconnected to the first. In other words, if you connect the +ve pin in the schematic to the Vdd net (for example), the PCB acts as though the second +ve pin is unconnected.
Is there a way to invoke this second pin for use? The invoke command doesn't work...
