Forum Fonction show
  • Subscribers 186 subscribers
  • Views 1355 views
Fonction show
6466
6466 over 3 years ago
Bonjour
Eagle 9.6.2
Peut-on sélectionner une connexion sur le schéma et la visualiser automatiquement sur le PCB?
Can we select a wire on the schematic and visualize it automatically on the PCB?
    shabaz over 3 years ago in reply to 6466
    I see. I guess it isn't supported (to me it seems unlikely this is a configurable feature, if it were available then it should be permanently on). But I am just speculating, I am not 100% sure : (
  • 6466
    6466 over 3 years ago in reply to shabaz
    I have the last version of eagle
    When I select a wire on the PCB, he's enterely illumined but I don't see it on the schema and invertely also
    There's a screenshot on the EAGLE website that seems to imply it does support this feature, although it didn't in the past.
    However, I guess you just need to try it, and see if it does. It's not going to be a feature that needs to be enabled or disabled, because EAGLE only functions in a mode where it automatically tries to keep the schematic and PCB in sync. Have you downloaded and installed the free version?
    Otherwise, KiCAD certainly supports this feature, so I believe EAGLE will likely support it by now. But it should be checked with the free EAGLE version.
