Forum SAD1024
  • Subscribers 185 subscribers
  • Views 937 views
SAD1024
remon
remon over 2 years ago
Bonjour,
je recherché  se ICI  SAD1024 comment le tester avec oscilloscope je ne vois au cun tuto
Bonne Journee
Remon
    dougw over 2 years ago
    https://onedrive.live.com/?authkey=%21AGQFzD7VgT7oJ8Y&cid=444B58AD5BEBC7FA&id=444B58AD5BEBC7FA%21467&parId=444B58AD5BEBC7FA%21591&o=OneUp
    https://www.youtube.com/watch?v=JzhF-IrprMM&ab_channel=ThomasScherrerOZ2CPUTeardown
    Jan Cumps over 2 years ago
    This is a 2 channel analogue bucket IC. Datasheet contains test setup.
    If it is already in a circuit, you can provide a signal and:
    - check input a. It should have a signal with 6V dc and max  2Vpp  ac
    - check the clock signal, count the clock cycles. After 512 (or 1024 if in serial configuration) half clocks, the input should have moved through all buckets
    - check the output. Is the signal time-shifted as expected based on the input.
