Forum Eagle 4.14
  • Replies 33 replies
  • Subscribers 185 subscribers
  • Views 5900 views
Eagle 4.14
amilcar.brr
amilcar.brr over 1 year ago
Hi all,
I would like to explore this version for educational purposes, but I can't find it on the web.
Could someone please point me to a link where I can get this version of CadSoft Eagle 4.14 if it still exists?
Best regards.
  • geralds
    0 geralds over 1 year ago in reply to amilcar.brr
    well, yes. You can saving or not. The diodes make an "serial resistor" about few Ohm's at about 1 volt.
    May be then that LEDs may lightning a bit brighter without the diodes.
    If you want to saving, just use a wire bridge instead of the two diodes.
  • amilcar.brr
    0 amilcar.brr over 1 year ago in reply to geralds
    Hi Gerald,
    You are right, this is indeed the circuit to reproduce the KITT effect. What good times.
    Where I am at the moment I cannot edit your schematic but I would suggest saving two diodes, D1 and D10, as there will never be a return signal in these two lines.
    Once again, thank you very much for sharing.
    All the best.
    Amilcar
  • geralds
    Hi Amilcar,
    yes I remember me. That was a time in happy electronics. Sunglasses
    Here is a circuit of an interpreted of the KITTs scanner lamps.
    And the project files, saved in Eagle version 7.7.0:
    kitt knight rider.zip
    Best Regards
    Gerald
  • amilcar.brr
    Hi Gerald,
    What can I say? Amazing.
    I am completely amazed by your contribution.
    I remember, from my university days, using the LM555 in some elementary projects.
    I assume these projects were related to the attempt to reproduce the effect presented on the front of the KITT car in the Knight Rider TV series.
    Some projects were actually successful, others made good approximations, I think that's the case in our old robotics group.
    What started as a simple software scan turned into an excellent lesson in how Eagle works.
    For me, as a first time CardSoft Eagle user, what this community has done to help us has been extraordinary.
    This reveals the essence of human beings, sharing knowledge.
    Best Regards to all and Merry Christmas.
    Amilcar
  • geralds
    this schematic - application - a clock driven decade counter is very old, since the 1980s or before.
    It's for kids one of the best to teaching in digital and analog technical as well.
    I have many, many... similar "blinky" - schematics.
    The "missing link" - your schematic reconstructed. Its just logical that this timer may be used.
    The wire from the pin S of the trimmer pot also was missing. With this wire it works correctly.
    The application description in the data sheet shows how does the timer work.
    The NE555 comes from Signetics (one of the oldest version).
    The LM555 comes from National.
    The CMOS version from National - LMC555.
    The CMOS version from Texas Instruments, TLC555.
    Some other manufactures have also build this timer in bipolar or CMOS technology.
    The Motorola version of the decade counter 4017 (this is one of the oldest version).
    You can use all kinds of this timers as well this (decade) counters.
    Best Regards
    Gerald
  • amilcar.brr
    0 amilcar.brr over 1 year ago in reply to Andrew J
    Hi Andrew,
    Thank you very much for your suggestions, of course we will take them into consideration.
    Best Regards and Merry Christmas.
  • amilcar.brr
    Hi geralds,
    Thank you very much for your contribution.
    The NE555 does indeed fit into the project, but was this the IC that was initially planned for the scheme? Who knows?
    Once again thank you very much for the time you spent helping us and also thanks for your tip.
  • geralds
    I've finished your schematic with the timer NE555.
    This was your schematic:
    This schematic I've completed with the timer and I created the PCB as well for you. The Cadsoft Eagle version is 7.7.0
    You can build a single side board and the red tracks can be a wire bridge. That via holes are in 0.8 mm.
    The project files:
    kitt-timer.zip
    I saved it in version 7.7.0; so you can easily convert it into KiCad.
    The latest version of Cadsoft Eagle is 9.6.0; ==> Autodesk Fusion 360.
    The version 9.6.0 will ending in 2026, so you can work with Fusion 360.
    Or, cheaper with KiCad, what I recommend for you.
    Tipp: the Cadsoft exe folder have a converter exe, which you can translate from the older versions to the newer versions.
    If you've saved your built files once in a newer version you cannot open the files with an older exe version.
    The missing details of some components in such files are marginal so you can easy insert a component or even creating it.
    Best Regards
    Gerald
  • Andrew J
    0 Andrew J over 1 year ago in reply to shabaz
    Agreed - that was my suggestion 4 days ago.  I don’t have time to open the zip but do / did older Eagle files contain XML?  In that case, the missing component may be named in the human-readable file even if missing as a symbol or footprint.
  • amilcar.brr
    0 amilcar.brr over 1 year ago in reply to shabaz
    Hi shabaz,
    Thank you very much for your attention to my matter.
    I didn't mention that the projects were carried out by students, I mentioned that they were part of a robotics group that included our entire school community.
    The message dougw put "Eagle design files do include all component information." led us to try to find, in our network of contacts, at least one of the group members to clarify some points, but so far it has not been possible to contact anyone.
    Since you show a lot of interest in helping us, I will publishy a file that has already been opened in Eagle version 5.11.0.
    I think this file that I'm going to send will not have any legal issues.
    In this case, from the file name we can identify that the missing component must be a Timer, but which one?
    By the way, I should mention that our first obstacle was not the Software but rather the 3.5'' floppy disk readers to get the files.
    Best reagrds.
    kitt.zip
