Forum Raspberry Pi 3 CadSoft Library - some added
  • Subscribers 187 subscribers
  • Views 845 views
  • pi 3
  • cad library
  • cadsoft eagle
  • raspberry pi
  • cadsoft library
  • raspberry pi 3
  • pi 3 cadsoft library
  • raspberry pi 3 cadsoft library
geralds
geralds over 9 years ago
Hi All,
Based to Joseph Man joeman  i updated some items in the Raspberry Pi 3 CadSoft Library file.
1) I activated the milling layer.
2) I added a mirrored RPI3 shield for eventually special usage.
e.g. the parts are mounted on "top" - the RPI pin header lays on the "bottom" side.
Well, normally the parts would mounted between RPI and shield 'top' face to face.
With the mirrored pcb (top looks to RPI) you can easily mount the parts on the outside of the pcb.
All of them are free to use but without any guaranties. Please check it before using it.
Best Regards,
Gerald
