Forum Edit a libraries eagle
  • Subscribers 187 subscribers
  • Views 465 views
cardmaker
cardmaker over 9 years ago
hello, i need to edit this part in eagle removing the two holes but im unable to move or delete , any help?
if not removed , there will be two holes in pcb right?
  • geralds
    geralds over 9 years ago
    In the library search the layer - normally used the layers Document, fPlace, or tDocu layer - that they are active (highlight- or selectable).
    Then you can erase or move the items in that layer.
    Or holes layer, or special layers are used.
    But bevor you do this in the original lbr file, I suggest that you make a copy of this part in an "user" lbr file.
    Gerald
