Forum EAGLE  - How to name schematic sheets
  • Subscribers 189 subscribers
  • Views 3340 views
  • eagle 8
  • eagle schematic
justinmreina
justinmreina over 9 years ago
How do you name sheets and have the name used for selection? Here is an example I found -
For example, how can I get sheet 1 named 'Analog Inputs & Processing'? Super curious and I feel like I've tried everything, let me know your thoughts!
  • justinmreina
    justinmreina over 9 years ago in reply to rachaelp
    This works, thank you! Here is what I found -
    1. Navigate to target schematic page (e.g. Sheet 1 for me here, '1/5')
    2. Either:
            *Enter "Description" into the text-entry bar and press enter. Fill out the popup
            *Enter "Description new sheet name" into the text-entry bar and press enter
            *Navigate to Edit->Description->Sheet from the menu bar. Fill out the popup
    See below for where to click in EAGLE. This took a little effort, sharing this for simplicity for future users!
    Original Sheet Title
    After pressing 'Enter'
    Here is how the names are updated for the Control Panel listings -
    • Schematic - Select 'Edit->Description->Schematic' and give value
    • Board - "Description new name" into the text-entry bar for the Board
  • rachaelp
    rachaelp over 9 years ago
    Hi Justin,
    Right click on the sheet thumbnail and click on "Description". Then when you type in the description it takes whatever is on the first line as the name shown in that list.
    Best Regards,
    Rachael
