Forum ESP8266 lbr file
  • Replies 15 replies
  • Subscribers 189 subscribers
  • Views 9664 views
ESP8266 lbr file
foxeater
foxeater over 8 years ago
Hey Gang,
I was trying to find the lbr file for the ESP8266.  It's a wifi communicator for arduino.  I need the .lbr to simulate it in EAGLE if it exists.  Can someone tell me where to find it?  Thanks!
Regular Guy
Semper Paratus
  • luislabmo
    luislabmo over 8 years ago in reply to foxeater
    Haha foxeater that is one heck of a poem for sure! Thank you. Glad I helped. image
    I'm gonna add that poem to the ESP8266's part description in Eagle Cad. Every time I use that part, for sure I will read it.
    Luis
  • foxeater
    Call the designer of the wifi modules.
    The explicit one, and bid him code
    In .lbr files ergonomic components.
    Let the girls try to date him so their children
    Can have high salaries, and let the boys
    Bring him poems written in Word.
    Let be be finale of seem.
    The only emperor is the emperor of the ESP8266.
    Give to the element 14,
    Lacking of the EX version, that component
    On which the regular guy will fail to find
    And reply so as to compensate his witlessness.
    If the reply amount protrudes,
    Showing how slow he is and dumb.
    Let your lamp affix its beam.
    Resolved with this .lbr - https://www.dropbox.com/s/e5ot49h4rarkhog/LuisLab-Boards.zip?dl=0 luislabmo
    Special thanks to: luislabmo
  • foxeater
    LOL, I didn't use YOUR library the whole time.  I finally found it.
    I owe you one heck of a poem!
  • luislabmo
    I see, that looks like the part for the ESP8266 Thing if you want to incorporate it your design. The one I provided you will work for the one you sent in the picture. No need of Sparkfun's library.
  • foxeater
    *I have only one ESP8266.  I went to github and found the master folder that has the RF SparkFun components.  Still, to no avail.
  • foxeater
    I just get on of them, and it looks like this:
  • foxeater
    foxeater over 8 years ago in reply to luislabmo
    You're correct!  I'll have to make sure I looked up the right guy.
  • luislabmo
    Hello Regular Guy,
    The one I gave you works exactly for that module. It has 8 pins, and technically the footprint requires a 2x4 0.1" pitch female header.
  • foxeater
    Image result for ESP8266
  • luislabmo
    The one I gave you only uses 8-pins (ESP8266 ESP-01), maybe you need a part for a different one? I think the other one that uses 8 pins is the ESP-02. It would be better if you post a picture of the module you have/plan to use.
