Forum where to find model zener diode for Eagle ?
  • Views 2327 views
  • simulation
  • eagle 8.4
  • spice_model
  • spice models
khunpoumg
khunpoumg over 8 years ago
In Autodesk Eagle Version 8.4.0 have built-in simulator (Ng-SPICE) simulator, but this simulator works only with components from one built-in small library such as resistors, diodes, but have not zener diodes model for simulate
files models have extention MDL
Where i can find library (LBR) with zener diode and compatable with Eagle simulator or model file (MDL) for it?
https://www.autodesk.com/products/eagle/blog/spice-simulation-part-4-transient-analysis-spice-model-mapping/
  • rachaelp
    rachaelp over 8 years ago
    The .MDL files are just standard SPICE format files so any manufacturer that provides standard SPICE models for their parts are a good place to start in looking for a suitable Zener model. You can rename the file extension to .MDL or you can copy/paste the contents of the file into the add model dialog in EAGLE. Note that some companies provide LTSPICE libraries, but these are a format which is a proprietary format relating only to Linear Tech's LTSPICE simulator so are not usable.
    Best Regards,
    Rachael
