Forum Amphenol RJ08 - RJ45 top entry connector
  • Subscribers 190 subscribers
  • Views 2315 views
den_olli
den_olli over 8 years ago
Does anyone knows where I can find a library file that includes the RJ08 connector?
http://www.farnell.com/datasheets/1924593.pdf?_ga=2.18973368.1043618546.1517398250-1443909419.1517398250&_gac=1.23823186…
Or the Molex RJ45 would also be ok
http://www.farnell.com/datasheets/2129596.pdf?_ga=2.28895676.1043618546.1517398250-1443909419.1517398250&_gac=1.49548178…
  • den_olli
    I found a lib with a vertical RJ45 connector that exactly the same. If anyone else need this, see the attached file
    con-rj-modified.zip
    genebren over 8 years ago
    Olivier,
    It looks like the footprint on the conn-mloex.lbr - 0446200001 part would work.  The outline might be off a bit as this is a side entry part, but the pins and mounting holes look to be correct.  I have found a lot of the rj45 connectors (even from different vendors) have identical footprints.
    Good luck!
    Gene
  • rachaelp
    rachaelp over 8 years ago
    Hi Oliver,
    My first suggestion would be just learn to create library parts yourself. It's generally pretty easy. I've written a tutorial series about creating library parts in EAGLE.
    EAGLE Tutorial: Library Part Creation Part 1 - Creating Packages
    My other suggestion would be to look at Wurth parts as an alternative. They do lots of connectors like these and they supply EAGLE library parts for the vast majority of their offerings. Check out http://www.we-online.com
    Best Regards,
    Rachael
