Forum Airwire problem
  • Subscribers 190 subscribers
  • Views 1255 views
  • autocad
  • eagle 9.0.0
Airwire problem
sayedabbas722
sayedabbas722 over 8 years ago
Hello Everyone.
recently I try make board for micro controller 32u4 in eagle but i getting some air wire error
I can't understand this and I am also beginner.
This is ground air wire which connect through the IC and I also define the polygon on top and bottom this is my problem. i can't connect them through IC.I share photo also and please help for this error.
  • rachaelp
    rachaelp over 8 years ago in reply to sayedabbas722
    So you need to add in vias to connect your currently unconnected ground pins to your ground plane. I just had a look through the datasheet for the 32u4 hoping to see that that large centre pad described as a ground pad but it gets no mention. It's possible you could connect that to ground and then your ground pins can then connect to that pad but I am not sure because the datasheet doesn't say whether it connects to anything internally to the device or not.
    Best Regards,
    Rachael
  • sayedabbas722
    sayedabbas722 over 8 years ago in reply to rachaelp
    balearicdynamics over 8 years ago in reply to rachaelp
    No only for you rachaelp
    image Enrico
  • rachaelp
    Unfortunately your photo isn't showing for me. Could you try uploading it again?
    Best Regards,
    Rachael
