Forum PCB design that is free and very similar or cheaper than Altium
  • Replies 12 replies
  • Subscribers 193 subscribers
  • Views 7861 views
jackmarison93
jackmarison93 over 7 years ago
I wanted to know if that is an alternative type of PCB design that has a similar interface and design like Altium because the price is ridiculous
  • BigG
    BigG over 7 years ago
    If you want an online option that is very easy to get going, then I would recommend https://easyeda.com/
    I find it has great import options and you can download your design files for safekeeping etc.
    Otherwise, I too like to use the KiCad EDA although I find this takes much longer to learn compared to easyeda.
    michaelkellett over 7 years ago in reply to Jan Cumps
    That's certainly true - all reviews should be interpreted in the context of what you know about the reviewer.
  • michaelwylie
    michaelwylie over 7 years ago
    I use CircuitStudio all the time and I've only had minor issues. The problems people have are usually stemmed from buying CircuitStudio and expecting the functionality of Altium Designer.
    Jan Cumps over 7 years ago in reply to michaelkellett
    michaelkellett , the thing is that there are tons of these kind of posts for each of the EDA packets. When they are written in that tone, I shift them aside.
  • 14rhb
    14rhb over 7 years ago in reply to e14softwareuk
    Eagle has a area on E14 Community Autodesk EAGLE
    And an Autodesk rep you can ask questions of Jorge_Garcia
  • Fred27
    Fred27 over 7 years ago
    Eagle is good and it's what I use, but the one requirement the OP has is "has a similar interface and design like Altium"
  • e14softwareuk
    e14softwareuk over 7 years ago in reply to Sean_Miller
    Eagle is a great product and is free if you are working on small designs or very low cost subscription if only needing 4 copper layers and limit board size. The new Eagle under Autodesk is very different to the old days as there are many, many releases of the software each year with both bug fixes and new features regularly getting added.
  • Sean_Miller
    Sean_Miller over 7 years ago
    Before KiCAD came along, Eagle was the Go-To free PCB design software from Cadsoft.  Today, Autodesk owns Eagle and they have integrated Autodesk Fusion 360 with it.
    KiCAD does great to render a 3D asset from your board design, but I have found the Fusion solution more streamlined if you are one to make your own enclosures.  You can go straight from the PCB design to Fusion 360 Design.  So, I'm back to Eagle as my primary.
    See ya',
    Sean
    michaelkellett over 7 years ago in reply to Fred27
    Before rushing into that I suggest you check out the discussions re. Circuit Studio on E14 - the purchasers of that product do not seem very happy.
    @ Jack, if you must have free then Kicad is almost certainly the way to go.
    If mere cheap might do then take a look at EasyPC, easy to use and in my experience it's been very reliable. Very few crashes or problems of any kind in more than 10 years of using it. Much simpler and less ambitious than Altium and other big ticket products but that'll be why it's cheap but actually works.
  • Fred27
    I was also going to suggest Circuit Studio. I've not used it myself, but I know it's intended to be a subset of AD.
