Forum PCB design that is free and very similar or cheaper than Altium
  • Replies 12 replies
  • Subscribers 185 subscribers
  • Views 7122 views
jackmarison93
jackmarison93 over 7 years ago
I wanted to know if that is an alternative type of PCB design that has a similar interface and design like Altium because the price is ridiculous
  • e14softwareuk
    e14softwareuk over 7 years ago in reply to Sean_Miller +4
    Eagle is a great product and is free if you are working on small designs or very low cost subscription if only needing 4 copper layers and limit board size. The new Eagle under Autodesk is very different…
  • Sean_Miller
    Sean_Miller over 7 years ago +2
    Before KiCAD came along, Eagle was the Go-To free PCB design software from Cadsoft. Today, Autodesk owns Eagle and they have integrated Autodesk Fusion 360 with it. KiCAD does great to render a 3D asset…
  • 14rhb
    14rhb over 7 years ago in reply to e14softwareuk +2
    Eagle has a area on E14 Community Autodesk EAGLE And an Autodesk rep you can ask questions of Jorge_Garcia
    michaelkellett over 7 years ago in reply to Jan Cumps
    That's certainly true - all reviews should be interpreted in the context of what you know about the reviewer.
  • BigG
    BigG over 7 years ago
    If you want an online option that is very easy to get going, then I would recommend https://easyeda.com/
    I find it has great import options and you can download your design files for safekeeping etc.
    Otherwise, I too like to use the KiCad EDA although I find this takes much longer to learn compared to easyeda.
