Autodesk EAGLE
Autodesk EAGLE
Files The element14 Arduino CadSoft Library (Rev C)
  • Next
  • Previous
  • Author Author: joeman
  • Views 40637 views
  • Downloads 2652 downloads
  • Likes 20 likes
  • Comments 75 comments
We are pleased to offer our very own CadSoft library for Arduino--for free!  Our new library simplifies Arduino shield development by placing the most-popular Arduino pinouts right at your fingertips.  The latest version includes these boards: 101, Uno, Nano, Mini, Micro, Mega2560, Lilypad, Leonardo, Ethernet, and Due
Don't yet have CadSoft EAGLE?
Get your copy here!
Let us know what you think by posting comments below, and thanks for being a part of the element14 community!
  • pinout
  • arduino pinout
  • eagle_library
  • cadsoft
joeman
joeman
  • 28 Oct 2013
  • 2,652 Downloads
  • DaveYoung
    DaveYoung over 11 years ago in reply to cap269 +2
    Hi Andrew- This library references the MEGA2560. I think it could be labeled better, so I'll add that change to the next library revision. There are a few differences between the two on the pin headers…
  • tronixstuff
    tronixstuff over 13 years ago +1
    Well done, very useful.
  • DaveYoung
    DaveYoung over 12 years ago in reply to Workshopshed +1
    Hi Andy- This library has the Due, Ethernet, Leonardo, Lilypad, Mega, Micro, Mini, Nano, and Uno boards. Thanks for asking about the Micro Pro - it helps for determining which ones would be useful to add…
  • robbycandra
    robbycandra over 9 years ago
    Thankyou very much.
  • owis2sabry
    owis2sabry over 9 years ago
    thank you for this helpful lib
  • rlc4
    rlc4 over 9 years ago
    Thanks for creating the library, it's very useful.
    I have a project that I was using an Arduino Pro Mini (and grabbed the lbr from somewhere else).  Due to constraints I had to shift to a Arduino Micro and found this library.
    After re-working for the right pins, etc I went to use auto-router as I had with the earlier device.  I discovered that for some reason auto-router wouldn't connect to any of the pins on the Micro.
    After a bit of digging, I think this problem exists on all of the devices in this library: The "Dimension" layer is used for the outlines of the devices.  Unfortunately, auto-router sees this as a hard edge of the board (and your pcb maker may as well!).
    Ideally this outline should be on a different layer (21 - tPlace, 51 - tDocu) (ref 1:  EAGLE Help: LAYER  ref 2: Introduction to EAGLE – Understanding layers | Robotics, Teaching & Learning  )
    If you're a fan of the auto-router and need to make this change yourself manually:
    - From the "Libraries" portion, select the device you want to change
    - 'Open in Library' (yeah, seems counter-intuitive).
    - Select 'Package' to get into the editor for the package.
    - Using the wrench icon, select a new layer
    - click on those parts of the schematic that you want to move to the new layer
    - repeat using the wrench icon to move items to other layers as appropriate.
    Hope this is useful information, my pcb now auto-routes perfectly.
  • czemacleod
    czemacleod over 9 years ago
    I notice it doesn't include the Ardunio Pro Mini
  • jj4
    jj4 over 9 years ago
    This is great! Thanks image
