Autodesk EAGLE
Autodesk EAGLE
Documents Cypress Semiconductor CAD Libraries for Cadsoft EAGLE Software
  • Author Author: atomar
  • Date Created: 30 Apr 2012 3:10 AM Date Created
  • Last Updated Last Updated: 8 Oct 2021 7:43 AM
  • Views 2621 views
  • Comments 5 comments
element14 provides consolidated Cadsoft EAGLE CAD libraries to reduces the efforts and time put into by our EDE customer in PCB design process while creating CAD Library for specific part in a design. The provided CAD libraries has both Symbols and Footprints (Device, Symbol & Package) information and developed as per IPC standards to meets all industrial PCB design requirements. Every CAD library has part information along with Farnell and Newark order codes which helps in creating final Bill of Materials with the suppliers order codes.
This EAGLE CAD library covers a range of Cypress Semiconductor devices like SoC, memory, clock management IC's etc. This library is provided in a downloadable ZIP format which includes below files:
1. Cypress Semiconductor Library (.lbr) file
2. List of components in the library (PDF)
3. Readme file - Gives step by step instruction on how to import and use the library file into the Cadsoft EAGLE software.
imageCypress_Library_Components_List.pdf
Cypress_Library.zip
  • clock-management
  • clock
  • eagle
  • soc
  • footprint
  • library
  • memory
  • cad
  • cypress_semiconductor
  • symbol
  • cadsoft
    e14 Contributor over 11 years ago in reply to Workshopshed +1
    Thank you for your prompt response, Workshopshed !! I ended up using DipTrace to create a new component. Thank you, again! Regards, Ajay
  • ajaybiradadr
    ajaybiradadr over 3 years ago
    i need
    CY8C4025AZI-S413 this cypress controller library file required
    Thank you for your prompt response, Workshopshed!!
    Regards,
    Ajay
  • Workshopshed
    Workshopshed over 11 years ago in reply to e14 Contributor
    Hi Ajay, I made my own for the one device I needed.
    http://www.element14.com/community/community/cadsoft_eagle/blog/2014/11/01/building-a-library-in-eagle
    If that's the one you need then I can upload it but I've not actually tested it with a really PCB yet.
    Hello Workshopshed,
    Were you able to find the MBR3 library? If yes, could you please share the details.
    Thanks,
    Ajay
  • Workshopshed
    Workshopshed over 12 years ago
    Is there an updated version of this library with the MBR3 mechanical button replacement devices?
