Autodesk EAGLE
Autodesk EAGLE
Documents International Rectifier CAD Library for Cadsoft EAGLE Software
  • Author Author: atomar
  • Date Created: 2 May 2012 3:10 AM Date Created
  • Last Updated Last Updated: 8 Oct 2021 7:43 AM
  • Views 4181 views
  • Comments 8 comments
element14 provides consolidated Cadsoft EAGLE CAD libraries to reduces the efforts and time put into by our EDE customer in PCB design process while creating CAD Library for specific part in a design. The provided CAD libraries has both Symbols and Footprints (Device, Symbol & Package) information and developed as per IPC standards to meets all industrial PCB design requirements. Every CAD library has part information along with Farnell and Newark order codes which helps in creating final Bill of Materials with the suppliers order codes.
This EAGLE CAD library covers a range of International Rectifier MOSFET Drivers, Amplifiers and Display Drivers. This library is provided in a downloadable ZIP format which includes below files:
1. International Rectifier Library (.lbr) file
2. List of components in the library (PDF)
3. Readme file - Gives step by step instruction on how to import and use the library file into the Cadsoft EAGLE software.
imageInternational_Rectifier_Library_Components_List.pdf
International Rectifier.zip
  • international_rectifier
  • eagle
  • footprint
  • library
  • drivers
  • cad
  • amplifiers
  • display_driver
  • mosfet_drivers
  • ir
  • symbol
  • cadsoft
  • gamecompiler
    gamecompiler over 11 years ago in reply to e14 Contributor
    Your post is a long time ago, but today id downloaded the library.
    It works.
    Sorry for my english
  • lawrence.porter
    lawrence.porter over 11 years ago
    The International Rectifier library does work, but it is missing a bunch of the newest IR devices.
    Why IRF3205 is not included in this library and where can I find IRF3205 mosfet?
  • gehan_s
    gehan_s over 11 years ago
    Do you have the  irams10up60a part (or at-least something similar)
    I am looking for an IRF7404 any idea where I can locate this component? I have downloaded Eagles CAD and components and I have downloaded the extended cad files here and I am not able to locate this particular component.
    Thank you in advance
    This download is not working.
    Having the same problem as emilio, help would be appreciated image
    Is the link still working? I'm trying to download the files but i can't, the explorer displays this error message:
    Error
    An general error occurred while processing your request.
    If someone could help me i will be very pleased
    Greetings!
