Autodesk EAGLE
Autodesk EAGLE
Documents Maxim CAD Library for Cadsoft EAGLE Software
  • Author Author: atomar
  • Date Created: 2 May 2012 3:33 AM Date Created
  • Last Updated Last Updated: 8 Oct 2021 7:43 AM
  • Views 7225 views
  • Comments 30 comments
element14 provides consolidated Cadsoft EAGLE CAD libraries to reduces the efforts and time put into by our EDE customer in PCB design process while creating CAD Library for specific part in a design. The provided CAD libraries has both Symbols and Footprints (Device, Symbol & Package) information and developed as per IPC standards to meets all industrial PCB design requirements. Every CAD library has part information along with Farnell and Newark order codes which helps in creating final Bill of Materials with the suppliers order codes.
This EAGLE CAD library covers a range of Maxim devices like Clock Management, Microcontroller Memory Modulators, Power_Manageent, Controllers, Converters, Transceivers, Multiplexers, Amplifier, Potentiometers, Sensor, Drivers, Comparators etc. This library is provided in a downloadable ZIP format which includes below files:
1. Maxim Library (.lbr) file
2. List of components in the library (PDF)
3. Readme file - Gives step by step instruction on how to import and use the library file into the Cadsoft EAGLE software.
imageMaxim_Library_Components_List.pdf
Maxim.zip
  • clock_management
  • transceivers
  • eagle
  • modulators
  • footprint
  • amplifier
  • library
  • drivers
  • potentiometers
  • converters
  • memory
  • cad
  • multiplexers
  • microcontroller
  • Controllers
  • maxim
  • comparators
  • symbol
  • sensor
  • cadsoft
  • power_manageent
    e14 Contributor over 10 years ago +1
    DS1307Z+ and DS1307ZN+ pin 5,6,7 have wrong name based on datasheet. Symbol Datasheet 5 SQW/OUT 5 SDA 6 SDA 6 SCL 7 SCL 7 SQW/OUT
  • hani-md
    hani-md over 6 years ago
    Hi
    Why there is no MAX4616 in this library?
    I want to use it in my Eagle Desktop work
    Thanks
    Pls contact me at hani-md@utm.my
    shabaz over 8 years ago in reply to dk30713
    I don't know about that, but in any case, the fact is this file is old, and won't help for modern parts.
    If the requirement is that you're looking for a CAD file (for EAGLE or other software) for a specific Maxim part, then if you go directly to the Maxim website and type your part number, and it will provide you with the file for the specific part in question. For EAGLE, it provides a script (.scr) file that you can execute from within a library file.
    The link is: https://www.maximintegrated.com/en/design/design-tools/cad-and-layout/cad.html
  • dk30713
    dk30713 over 8 years ago
    well, thanks, so maxim dont care if we use their parts ?
    consider if it takes us designers shorter time to find parts with similar features, WITH updated eagle lib,
    from other source, compared to making the lib our self.. just saying..
    Hi,
    It's a library from 2012, last updated in May of that year. It will be missing all modern parts (and probably some old ones).
  • dk30713
    all the parts i needed are missing in this lib..
    MAX14626, MAX17620, MAX17502, MAX15062
  • ianvenner
    ianvenner over 8 years ago
    MAX1044?
  • lalo-
    lalo- over 8 years ago
    ds1307 worng pin name 5,6, and 7
  • @xi@g@me
    @xi@g@me over 8 years ago in reply to shabaz
    oh sh## just saw on the maxim integrated site they are not produced any more, indeed. Then I'm screwed, I have to find another way of designing what I need
    shabaz over 8 years ago in reply to @xi@g@me
    That's obsolete too. Where will you obtain the IC from?
  • @xi@g@me
    Yes, SCART. I simply plan to create my own 8 to 1 SCART switch instead of buying one (yes, I know, they are not so much expensive, and I can easiliy find them on the internet. But you know, curiosity and experience...). I'll try to follow the tutorial. Otherwise I can use other chips, like the MAX4399 (which also does audio, but I'll have to use I²C to communicate with it)
