Autodesk EAGLE
Autodesk EAGLE
Documents NXP CAD Library for Cadsoft EAGLE Software
  • Author Author: atomar
  • Date Created: 2 May 2012 3:38 AM Date Created
  • Last Updated Last Updated: 8 Oct 2021 7:43 AM
  • Views 5051 views
  • Comments 12 comments
element14 provides consolidated Cadsoft EAGLE CAD libraries to reduces the efforts and time put into by our EDE customer in PCB design process while creating CAD Library for specific part in a design. The provided CAD libraries has both Symbols and Footprints (Device, Symbol & Package) information and developed as per IPC standards to meets all industrial PCB design requirements. Every CAD library has part information along with Farnell and Newark order codes which helps in creating final Bill of Materials with the suppliers order codes.
This EAGLE CAD library covers a range of NXP devices like Inverters, Decoder, Drivers, Multiplexer, Microcontroller, Memory, Transceiver, PLL, USB/CAN Interface, Amplifiers, Transistors, Diodes, LDO's etc. This library is provided in a downloadable ZIP format which includes below files:
1. NXP Library (.lbr) file
2. List of components in the library (PDF)
3. Readme file - Gives step by step instruction on how to import and use the library file into the Cadsoft EAGLE software.
imageNXP_Library_Components_List.pdf
NXP.zip
  • eagle
  • multiplexer
  • pll
  • footprint
  • ldo
  • library
  • drivers
  • transceiver
  • inverters
  • memory
  • cad
  • usb/can
  • amplifiers
  • microcontroller
  • transistors
  • diodes
  • interface
  • nxp
  • symbol
  • cadsoft
  • decoder
  • kzalezak
    kzalezak over 9 years ago +1
    Nice job but missing 74HC4067DB - 16-channel analog multiplexer/demultiplexer 24SSOP
  • inlifeindeath
    inlifeindeath over 8 years ago in reply to e14 Contributor
    Did you ever find a LFPAK56D Eagle part?
  • johnymielony
    johnymielony over 8 years ago
    There is PCA9632, there is PCA9634, but why PCA9633 is gone?
  • kzalezak
  • phhlxlbe
    phhlxlbe over 10 years ago in reply to e14 Contributor
    I think this library is Eagle V6 compatible. Also you cannot import this directly in V5. You can try following these steps:
    Download Eagle V 6 (The V5 and V6 can be installed on the same computer)
    Import the library with Eagle 6 and open it.
    Create the library in V5 and open it.
    After process with copy and paste as you copy a device between 2 libraries.
    I hope this somment helps you
    I have downloaded the library but Eagle keeps saying "invalid data" in the file ".lbr". I am using Eagle 5.10. Any idea?
    Regards
    Any chance of LFPAK56 and LFPAK56D ?
  • arkanoid_376970
    arkanoid_376970 over 11 years ago
    Missing HEF4050BT Non-Inverting Hex Buffer
  • dmikeleit
    dmikeleit over 12 years ago
    I've posted this in the support forum, they will fix it:
    Download links not working
  • riaco
    riaco over 12 years ago
    same issue - download not working due to general error
    Download link not working.
