Autodesk EAGLE
Autodesk EAGLE
Documents Multicomp CAD Library for Cadsoft EAGLE Software
  • Author Author: atomar
  • Date Created: 8 May 2012 3:57 AM Date Created
  • Last Updated Last Updated: 8 Oct 2021 7:44 AM
  • Views 3672 views
element14 provides consolidated Cadsoft EAGLE CAD libraries to reduces the efforts and time put into by our EDE customer in PCB design process while creating CAD Library for specific part in a design. The provided CAD libraries has both Symbols and Footprints (Device, Symbol & Package) information and developed as per IPC standards to meets all industrial PCB design requirements. Every CAD library has part information along with Farnell and Newark order codes which helps in creating final Bill of Materials with the suppliers order codes.
This EAGLE CAD library covers a range of Multicomp Resistors. This library is provided in a downloadable ZIP format which includes below files:
1. Multicomp Library (.lbr) file
2. List of components in the library (PDF)
3. Readme file - Gives step by step instruction on how to import and use the library file into the Cadsoft EAGLE software.
imageMulticomp_Library_Components_List.pdf
Multicomp.zip
  • eagle
  • footprint
  • library
  • cad
  • multicomp
  • resistor
  • symbol
  • cadsoft
    e14 Contributor over 11 years ago +1
    Only has multicomp resistors - no jack sockets
  • tanmayfuse1221
    tanmayfuse1221 over 5 years ago
    can you please add usb connector in library
  • nantonos
    nantonos over 12 years ago
    It seems as if this library should either be called "Multicomp resistors" or alternatively, and preferably, have other components such as Multicomp capacitors added.
