Autodesk EAGLE
Autodesk EAGLE
Documents Panasonic CAD Library for Cadsoft EAGLE Software
  • Author Author: atomar
  • Date Created: 8 May 2012 7:15 AM Date Created
  • Last Updated Last Updated: 8 Oct 2021 7:44 AM
  • Views 4493 views
element14 provides consolidated Cadsoft EAGLE CAD libraries to reduces the efforts and time put into by our EDE customer in PCB design process while creating CAD Library for specific part in a design. The provided CAD libraries has both Symbols and Footprints (Device, Symbol & Package) information and developed as per IPC standards to meets all industrial PCB design requirements. Every CAD library has part information along with Farnell and Newark order codes which helps in creating final Bill of Materials with the suppliers order codes.
This EAGLE CAD library covers a range of Panasonic Resistors. This library is provided in a downloadable ZIP format which includes below files:
1. Panasonic Library (.lbr) file
2. List of components in the library (PDF)
3. Readme file - Gives step by step instruction on how to import and use the library file into the Cadsoft EAGLE software.
imagePanasonic_Library_Components_List.pdf
Panasonic.zip
  • eagle
  • footprint
  • library
  • panasonic
  • cad
  • resistor
  • symbol
  • cadsoft
  • ejeyaseelan
    ejeyaseelan over 9 years ago +5
    just resistors? where does one get a library of Panasonic capacitors, thru hole and smd? what about other components that Panasonic makes?
  • kowaltski
    kowaltski over 9 years ago +2
    Yeah - i need libs for relays from panasonic...
  • majikcaesar
    majikcaesar over 9 years ago in reply to kowaltski +1
    Did you find libraries for other Panasonic parts? I'm looking for anything with a SOT-665 package...
  • majikcaesar
    majikcaesar over 9 years ago in reply to ejeyaseelan
  • majikcaesar
  • kowaltski
  • ejeyaseelan
    just resistors?
    • Vote Up +5 Vote Down
