Autodesk EAGLE
Autodesk EAGLE
Documents Analog Devices CAD Libraries for Cadsoft EAGLE Software
  • Author Author: atomar
  • Date Created: 10 Aug 2012 8:17 AM Date Created
  • Last Updated Last Updated: 8 Oct 2021 7:44 AM
  • Views 6635 views
element14 provides consolidated Cadsoft EAGLE CAD libraries to reduces the efforts and time put into by our EDE customer in PCB design process while creating CAD Library for specific part in a design. The provided CAD libraries has both Symbols and Footprints (Device, Symbol & Package) information and developed as per IPC standards to meets all industrial PCB design requirements. Every CAD library has part information along with Farnell and Newark order codes which helps in creating final Bill of Materials with the suppliers order codes.
This EAGLE CAD library covers a wide range of Analog Devices Inc device categories like Microcontroller, Supervisory Circuit, Power Management, Transistors, Voltage References, Transceiver, Encoder/ Decoder, I/O Expander, Converter, Digital POT, Operational Amplifier, Comparators, Amplifiers, Battery Management, Sensors etc. This library is provided in a downloadable ZIP format which includes below files:
1. Analog Devices library (.lbr) file
2. List of components in the library (PDF)
3. Readme file - Gives step by step instruction on how to import and use the library file into the Cadsoft EAGLE software.
imageAnalog Devices_By_element14_Batch_1.pdf
Analog Devices.zip
imageAnalog Devices_By_element14_Batch_2.pdf
Analog_Devices_Batch_2.zip
  • i/o
  • eagle
  • expander
  • management
  • digital
  • sensors
  • footprint
  • amplifier
  • converter
  • library
  • circuit
  • transceiver
  • cad
  • pot
  • amplifiers
  • battery
  • voltage
  • encoder/
  • microcontroller
  • transistors
  • operational
  • comparators
  • power
  • supervisory
  • symbol
  • cadsoft
  • references
  • decoder
  • cesar182
    cesar182 over 9 years ago
    I need the Analog Device library for Orcad, someone who can help me with this please?
  • darshitp
    darshitp over 9 years ago
    plz add Eagle lib for ic AD7757
    thank you,
    darshit
  • drabus
    drabus over 12 years ago
    Dear all,
    There is a mistake for component AD9959BCPZ in Analog Devices by element 14 batch 1 library:
    Pin n°28 is CH0_OUT and should be AGND
    Pin n°30 is AGND and should be CH0_OUT
    kind regards
    David
