Autodesk EAGLE
Autodesk EAGLE
Documents Texas Instruments CAD Libraries for Cadsoft EAGLE Software
  • Author Author: atomar
  • Date Created: 10 Aug 2012 8:39 AM Date Created
  • Last Updated Last Updated: 8 Oct 2021 7:44 AM
  • Views 18088 views
  • Likes 10 likes
  • Comments 57 comments
element14 provides consolidated Cadsoft EAGLE CAD libraries to reduces the efforts and time put into by our EDE customer in PCB design process while creating CAD Library for specific part in a design. The provided CAD libraries has both Symbols and Footprints (Device, Symbol & Package) information and developed as per IPC standards to meets all industrial PCB design requirements. Every CAD library has part information along with Farnell and Newark order codes which helps in creating final Bill of Materials with the suppliers order codes.
This EAGLE CAD library covers a wide range of Texas Instruments device categories like Buffers, Microcontroller, Supervisory Circuit, Power Management, Transistors, Voltage References, Transceiver, Encoder/ Decoder,  Converter, Digital POT, Operational Amplifier, Comparators, Amplifiers, Battery Management, Switches etc. This library is provided in a downloadable ZIP format which includes below files:
1. Texas Instruments library (.lbr) file
2. List of components in the library (PDF)
3. Readme file - Gives step by step instruction on how to import and use the library file into the Cadsoft EAGLE software.
Texas Instruments.zip
imageTexas Instruments_By_element14_Batch_1.pdf
  • eagle
  • management
  • digital
  • footprint
  • amplifier
  • switches
  • converter
  • library
  • circuit
  • buffers
  • transceiver
  • cad
  • pot
  • amplifiers
  • battery
  • voltage
  • encoder/
  • microcontroller
  • transistors
  • operational
  • comparators
  • power
  • supervisory
  • symbol
  • cadsoft
  • references
  • decoder
  • Yiying
    Yiying over 12 years ago in reply to e14 Contributor +3
    Hi You can download these libraries by clicking CAD Cadsoft EAGLE icon in farnell website. Below are the links: TPA3116: http://uk.farnell.com/texas-instruments/tpa3116d2dad/amp-class-d-26vin-2x50w-32htssop…
    e14 Contributor over 11 years ago +3
    this should be maintained on github.com then everyone could submit parts for inclusion. dumb to have it here, frozen and locked into zip
  • ssilberhorn
    ssilberhorn over 14 years ago +2
    Learn more at http://www.cadsoftusa.com/downloads/TI
  • jonhpeterson
    jonhpeterson over 6 years ago
    Parts:
    ads1115idgst and ads1115idgsr
    ads1114idgst and ads1114idgsr
    within each "pair above" the parts show different pin configurations.
    however, I can't find any such difference in the data sheet.
    each set look like the only difference is package quantity.
    but maybe it is there somewhere, and I can't see it.
    Thanks.
  • DonQ
    DonQ over 7 years ago
    Again... Square boxes with wires attached are NOT schematic symbols. Prime example... Amplifiers are triangles, quad op-amps should be drawn as 4 separate symbols, with power supplies as a separate symbol also. Complex parts should include enough internal working components to give an idea of the function, etc. The whole point of a schematic is to make the operation of the circuit more easy to understand for a HUMAN, not just as a connection net-list to the layout program.
    vs or vs imageimageimageimage
    It's easy. The manufacturer almost always includes a simplified block diagram of the device. Copy, connect to pins, use options of the library to parallel identical pins, etc. ***NOW*** you're creating a schematic. Before, you were just doing a drag-and-drop version of a text net-list. Very different.
  • vt23
    vt23 over 7 years ago
    Hello.
    Can you add TLV376 and TLV333 (single Op Amps = channel in the package) and then can you add similar TLVs with multiple Opamps = channels in the package, please.
  • alinp
    alinp over 8 years ago
    BQ24040 has pads 1,5,6 and 10 wrongly placed by 0.023mm, thus the distance between the pads is 0.127mm instead of 0.15mm.
  • tiitplakk
    tiitplakk over 8 years ago
    HDC2010 DSBGA-6 any suggestion for library file/footprint?
  • yo8tot
    yo8tot over 9 years ago
    LMH6629 please
    shabaz over 9 years ago in reply to vimalnegi
    Some of these like the TPS2044A that you mention are 'NRND' status i.e. 'not recommended for new designs' so may never end up in a library if they are not historically there.
    Anyway, Rachael's excellent documentation here has got you covered:
    EAGLE Tutorial: Library Part Creation Part 1 - Creating Packages
  • vimalnegi
    vimalnegi over 9 years ago
    All components listed in component list is not there in library...example TPS2044A,  SN75240PWR and many more... how to deal with it...please help...
  • ncc1701d
    ncc1701d over 9 years ago
    No Octal Fet bus SN74CBT3244 in the library
  • pawek23
    pawek23 over 9 years ago
    Please add CC1120 RF Transceiver.
