Autodesk EAGLE
Autodesk EAGLE
Documents ST Microelctronics CAD Libraries for Cadsoft EAGLE Software
  • Author Author: atomar
  • Date Created: 10 Aug 2012 8:57 AM Date Created
  • Last Updated Last Updated: 8 Oct 2021 7:44 AM
  • Views 8304 views
  • Comments 15 comments
element14 provides consolidated Cadsoft EAGLE CAD libraries to reduces the efforts and time put into by our EDE customer in PCB design process while creating CAD Library for specific part in a design. The provided CAD libraries has both Symbols and Footprints (Device, Symbol & Package) information and developed as per IPC standards to meets all industrial PCB design requirements. Every CAD library has part information along with Farnell and Newark order codes which helps in creating final Bill of Materials with the suppliers order codes.
This EAGLE CAD library covers a wide range of
ST Microelctronics device categories like Memory,  Microcontroller, Supervisory Circuit, Power Management, Transistors, Voltage References, Transceiver, Encoder/ Decoder,   Converter, Gates & Inverters,Regulators,Switches Operational Amplifier, Comparators, Amplifiers, Battery Management, Sensors etc. This library is provided in a downloadable ZIP format which includes below files:
1.
ST Microelctronics library (.lbr) file
2. List of components in the library (PDF)
3. Readme file - Gives step by step instruction on how to import and use the library file into the Cadsoft EAGLE software.
ST Microelctronics.zip
imageST Microelctronics_By_element14_Batch_1.pdf
  • eagle
  • regulators
  • management
  • sensors
  • footprint
  • amplifier
  • switches
  • converter
  • library
  • circuit
  • transceiver
  • inverters
  • gates
  • memory
  • cad
  • amplifiers
  • battery
  • voltage
  • encoder/
  • microcontroller
  • transistors
  • operational
  • comparators
  • power
  • supervisory
  • symbol
  • cadsoft
  • references
  • decoder
  • nolan.manteufel@gmail.com
    nolan.manteufel@gmail.com over 7 years ago
    STM32F103VGT not found in this library.
  • jhmin0602
    jhmin0602 over 8 years ago
    stm32l432kc not found. Please add to the library
  • hasim
    hasim over 8 years ago
    stm32f105rct76 not found this library
  • avinash333
    avinash333 over 9 years ago
    Hello,I could not find package for stm32l073 .Can you please update the library with this  package.
  • nag2903
    nag2903 over 9 years ago
    Hello Sir,
    I could not find ST7580. Can you please upload new library.
  • narashiman
    narashiman over 10 years ago
    Hi, I am specifically looking for STBCFG01 flip chip library.. Pls help
  • rguna2003
    rguna2003 over 10 years ago
    Hi Anyone has library for STM32L443VC
  • phhlxlbe
    phhlxlbe over 10 years ago in reply to e14 Contributor
    Downgrades are rare, you can try this (BUT I have not tested):
    - Installs version 6 on a PC (many versions can be installed on the same PC BUT, of course, in different directories BUT the files brd and sch will be open with the last version installed - however, on Windows, you can change this in the "folder option").
    - In Version 6, try to export the library and then import it into your old version (with scr script)
    Please note that this possibility of downgrade will probably no longer possible with version 7 because the libraries use XML files
    e14 Contributor over 10 years ago in reply to e14 Contributor
    @  Arumugam Subramaniam is there any may to solve this?
    STP24DP05 please?
