Autodesk EAGLE
Autodesk EAGLE
Documents Amphenol CAD Libraries for Cadsoft EAGLE Software
  • Author Author: atomar
  • Date Created: 13 Aug 2012 5:22 AM Date Created
  • Last Updated Last Updated: 8 Oct 2021 7:44 AM
  • Views 3597 views
element14 provides consolidated Cadsoft EAGLE CAD libraries to reduces the efforts and time put into by our EDE customer in PCB design process while creating CAD Library for specific part in a design. The provided CAD libraries has both Symbols and Footprints (Device, Symbol & Package) information and developed as per IPC standards to meets all industrial PCB design requirements. Every CAD library has part information along with Farnell and Newark order codes which helps in creating final Bill of Materials with the suppliers order codes.
This EAGLE CAD library covers a wide range of
Amphenol device categories like Connectors, RF/Coaxial etc. This library is provided in a downloadable ZIP format which includes below files:
1.
Amphenol library (.lbr) file
2. List of components in the library (PDF)
3. Readme file - Gives step by step instruction on how to import and use the library file into the Cadsoft EAGLE software.
Amphenol_Library.zip
imageAmphenol_By_element14_Batch_1.pdf
  • connectors
  • eagle
  • footprint
  • library
  • cad
  • rf_coaxial
  • symbol
  • cadsoft
  • steve@teradiode.com
    steve@teradiode.com over 10 years ago
    There is only one connection to the 903-499J-51P2 component and that is to its center pin.  No terminal exists for any of its outer four ground pins to connect to.
    Its mounting hole diameters are close to the component's recommended sizes on its data sheet.  The default Amphenol SMB connector in Eagle has hole diameters smaller than that data sheet.  So that default footprint can be edited to increase hole sizes.
