Autodesk EAGLE
Autodesk EAGLE
Documents Molex CAD Libraries for Cadsoft EAGLE Software
  • Author Author: atomar
  • Date Created: 13 Aug 2012 6:04 AM Date Created
  • Last Updated Last Updated: 8 Oct 2021 7:44 AM
  • Views 11329 views
  • Comments 20 comments
element14 provides consolidated Cadsoft EAGLE CAD libraries to reduces the efforts and time put into by our EDE customer in PCB design process while creating CAD Library for specific part in a design. The provided CAD libraries has both Symbols and Footprints (Device, Symbol & Package) information and developed as per IPC standards to meets all industrial PCB design requirements. Every CAD library has part information along with Farnell and Newark order codes which helps in creating final Bill of Materials with the suppliers order codes.
This EAGLE CAD library covers a wide range of
Molex device categories like Connectors-Wire-To-Board,FFC / FPC etc. This library is provided in a downloadable ZIP format which includes below files:
1.
Molex library (.lbr) file
2. List of components in the library (PDF)
3. Readme file - Gives step by step instruction on how to import and use the library file into the Cadsoft EAGLE software.
imageMolex_By_element14_Batch_1.pdf
Molex_Library.zip
  • eagle
  • connectors_wire_to_board
  • footprint
  • _fpc
  • library
  • cad
  • ffc
  • symbol
  • cadsoft
  • cwworth
    cwworth over 12 years ago +2
    Please add series 43045 and 43650 parts.
    e14 Contributor over 12 years ago +1
    Hello, i need the libray CMC Molex SD-64333-100 (112 pin ). can you help me ? Regards
  • aziz_derraz
    aziz_derraz over 7 years ago +1
    Where can I find the CMC Header 32-circuit part 64334-0100 please?
  • aziz_derraz
  • torstene
    torstene over 8 years ago
    I am Looking for 75586 connector library. Do you have any Information About this?
  • logancircuits
    logancircuits over 8 years ago
    I'm looking for a Molex slimstack connector library, specifically this component: 504618-3410. Is this available anywhere?
  • rodneyw
    rodneyw over 9 years ago
    Is it possible to add 87438-0343
    1.50mm Pitch Pico-SPOXTm Wire-to-Board Header, Surface Mount, Right Angle, Shrouded, 3 Circuits, E...
  • alferpac
    alferpac over 9 years ago
    Hi,
    Is it possible to add micro sd socket 503182-1853?
    Regards.
  • paulonoce
    paulonoce over 9 years ago
    Olá. Se puder incluir 51338-0374
    Agradeço
  • jcaplinger
    jcaplinger over 9 years ago
    Would you be adding series 34825, specifically 34825-0124 to the library anytime soon ?
  • mehbub
    mehbub over 9 years ago
    Hi How may i get Molex 47219-2001 microSD connector library ? Is anyone can help please ?
  • talon2000
    talon2000 over 9 years ago
    Needs 22-28-8000 series
  • louvignes
    louvignes over 9 years ago
    Hi Inde library for Molex 39-30-0040 Header
