Autodesk EAGLE
Autodesk EAGLE
Documents The Raspberry Pi 2 CadSoft Library
  • Author Author: bluescreen
  • Date Created: 23 Feb 2015 4:44 PM Date Created
  • Last Updated Last Updated: 13 Oct 2015 7:20 PM
  • Views 4893 views
  • Comments 15 comments
element14 is pleased to offer our very own CadSoft library for the Raspberry Pi 2--for free! Our new library simplifiesRaspberry Pi 2 development by giving you instant access to the pinouts you need for building your own custom circuit. Just download the attached zip file and load the library into CadSoft.
Don't yet have CadSoft EAGLE? Get your copy here!
We hope you enjoy building with the amazing Raspberry Pi 2 and CadSoft. Thanks for being a part of our community!
e14_Rpi2_RevA.zip
  • raspberry_pi_2
  • pinout
  • eagle_library
  • cadsoft
  • bluescreen
    bluescreen over 11 years ago in reply to scitechindian +1
    We hope you enjoy using them!
  • jonhpeterson
    jonhpeterson over 11 years ago +1
    I must be missing something. These look like templates for building your own rpi2. I was expecting a template for building a HAT.
    e14 Contributor over 11 years ago in reply to e14 Contributor +1
    Yes, of course, Pi 2 and B+ have the same layout
  • je11
    je11 over 9 years ago
    VERY Cool. Thank you!
  • hamood
    hamood over 9 years ago
    thanks for this library but i just begainer in eagle and i want to convert this lib to pcb layout is this eny resources to do some thing like this
  • geralds
    geralds over 10 years ago in reply to e14 Contributor
    Look here,
    https://www.raspberrypi.org/documentation/hardware/raspberrypi/README.md
    Gerald
    Alright, You just share the library right ?
    I can't get schematic of SDRAM connection with BCM2835, Can you help on this issue or anyone ?
  • geralds
    Hi,
    you can it import very easy into the Altium Designer with its tools.
    Gerald
    Do you have Alitum CAD Files ?  It would be Great image
  • geralds
    geralds over 11 years ago
    Thank you for the nice PCB-lib.
    But it seem that some pads of the connector are not in place.
    Which grid have you used? - i saw in 1.27 mm, is it so?
    Do you created the connector also? Pin 1 is a little bit out of place.
    I hope i have a mistake, isn't it?image
  • paul1004
    paul1004 over 11 years ago
    Thanks very much.
    Thanks for the file, saves a lot of time image
