Autodesk EAGLE
Autodesk EAGLE
Documents The Raspberry Pi Zero W AutoDesk EAGLE Library
  • Author Author: e14phil
  • Date Created: 22 May 2018 1:09 PM Date Created
  • Last Updated Last Updated: 6 Oct 2021 9:37 PM
  • Views 11174 views
  • Comments 23 comments
element14 is pleased to offer our very own CadSoft library for the Raspberry Pi Zero W--for free!
Our new library simplifies Raspberry Pi Hat development by giving you instant access to the pinouts you need for building your own custom circuit. Just download the attached zip file and load the library into Autodesk EAGLE
  Raspberry Pi Zero W (v1.3) - RASPBERRY-PI - PCB symbolimage
Don't yet have AutoDesk EAGLE? Get your copy here!
We hope you enjoy building with the amazing Raspberry Pi and Autodesk EAGLE Thanks for being a part of our community!
This .LBR file was kindly provided by
SamacSys Logo
www.componentsearchengine.com
LIB_Raspberry_Pi_Zero_W_(v1.3).zip
  • jkittle99
    jkittle99 over 8 years ago +5
    Doesn't work for me trying to use in Eagle 9.1.2 Error: line 214, column 42: invalid/missing attribute 'pad' in tag <connect>
  • Eriond
    Eriond over 7 years ago +2
    You can fix this yourselves: Replace the first 44 occurances of <hole (lines 66 to 109) with <pad name="n" , where n is an incrementing number from 1 to 44. Save the file. Fixed!
  • matthew_scott
    matthew_scott over 5 years ago
    Waist of time Doesn't work same error as the others obviously they are not maintaining of fixing issues a good demonstration of their customer support.
  • kwestla@sandia.gov
    kwestla@sandia.gov over 6 years ago
    Library Broken image
  • citlali
    citlali over 6 years ago in reply to huloveif
    Hi! I'd like to take a look at your version. But it seems it doesn't exist anymore. Could it be possible for you to share it again? Thanks.
  • fjco
    fjco over 6 years ago
    found ransomware in file
  • dretful
    dretful over 6 years ago in reply to Eriond
    I make it 48 occurrences - thank tou.
  • pmays
    pmays over 6 years ago in reply to huloveif
    The file permissions doesn't allow me access.  I sent an access request in Google Drive.
    Thanks Felix
  • huloveif
    huloveif over 6 years ago in reply to Eriond
    Perfect Fix !
    Thank you so much !
    I uploaded the modified file here :
    https://drive.google.com/open?id=1TxwsSp5ShhBLWGrljSeYgWaYwMAzAb5K
  • Eriond
    <hole
    <pad name="n"
    shabaz over 7 years ago in reply to thebum
    Ah I see.. It is possible to modify the library component (first modifying the symbol and package) in EAGLE to add these, but requires a bit of practice. There are good instructions here: EAGLE Tutorial: Library Part Creation Part 1 - Creating Packages
    The main difficulty is knowing the position of the pins, they will be approx 2.54mm separated but may need eyeballing&measuring more closely with a ruler or even calipers (if you're accurate to within a quarter of a millimeter that's good enough for those connectors, so it doesn't need to be too precise). Once you have those dimensions, and followed through a few of those tutorials from Rachael, you'll be comfortable making the mods (please post the file if you can, to help others).
  • thebum
    thebum over 7 years ago in reply to shabaz
    One problem with that part is that the RUN and TV pins are missing.
