3M
  • 3M
3M
Forum DIY Non- Flamable heat increasing &anti static liquid
Join 3M to participate - click to join for free!
  • Replies 7 replies
  • Subscribers 9 subscribers
  • Views 1890 views
  • friction
  • cleaning
  • diy
  • liquid
  • buffing
  • heat energy
  • cd dvd
sneb
sneb over 8 years ago
Hi all,
How could I create a non-flammable liquid that will increase the temperature of  a polycarbonate surface (DVD disc ) for buffing with buffing wheel friction..
so I will soften the polycarbonate so it is malleable so the scratched surface can be smoothed out...
so it works like liquid used for this machine  http://www.reface.com.au/wp-content/uploads/2015/09/AC_Liquid_msds.pdf
page 20   Why is AC Liquid important?   https://cdn.shopify.com/s/files/1/0979/4174/files/3500_manual_REVA.pdf
        https://www.bing.com/images/search?view=detailV2&ccid=8DKC3Cxf&id=D39CDA8E9E87C1A02A4752797A77AA49DEBE58E2&thid=OIP.8DKC…
Any Help and advice will be much appreciated.....
    michaelkellett over 8 years ago in reply to sneb +4
    The price seems reasonable - the gloop probably contains some very fine abrasive - it would be hard to get this right by trial and error so I think I would just stockpile the real thing. If I had to reverse…
    michaelkellett over 8 years ago +3
    Judging by the data in the safety sheet the liquid is water with very little else added. It may be that the extra ingredients are important, and maybe not. Are you just looking to save money or is there…
    dougw over 8 years ago in reply to mcb1 +3
    Good point mcb1 - I use an automotive scratch remover compound on CDs and DVDs. It works on surface scratches but not on warps.
    Judging by the data in the safety sheet the liquid is water with very little else added. It may be that the extra ingredients are important, and maybe not. Are you just looking to save money or is there another reason. How much do they charge for the real stuff ?
  • sneb
    sneb over 8 years ago in reply to michaelkellett
    Hi Michael,
    thanks for the reply much appreciated...
    It's because the machine has been discontinued for three years now and just thinking about how I could create some for it when they stop making the liquid that's why I am interested. it costs $25 which is fine to  buy for now until the end of production. image
    It sounds like you have a dilute detergent (liquid soap) mixed with a thickening agent like talc.
    You could look up thickening agents and then look up their properties such as melting temperature and toxicity and hardness.
    Then try a bunch of experiments - carefully.
    mcb1 over 8 years ago
    You might want to look at buffing compounds used in the automotive industry.
    There are heaps of grades and the idea is that it slowly polishes the surface, which nowdays is a clear coat over the paint.
    If I had to reverse engineer it I'd try mcb1 and Doug's suggestions as a starting point.
  • sneb
    Thanks everyone for your help much appreciated
